Old 07-12-2005, 01:23 PM   #1
Question
insulating metal studs - help
I am helping with a remodeling job. It is an old brick building and the enterior has been framed out with metal studs 16"o.c. Should I use standard insulating bats. If so how do I keep it between the studs (typical wood framing I would staple the fins to the studs). Or, should I use blown insulation? I do not like because of the settling factor over time. Please help we need this done ASAP.
maintenance is offline   Reply With Quote
Old 08-02-2005, 04:42 PM   #2
aka:awesomedell
Send a message via MSN to housedocs
Generally if it's framed correctly, standard faced batts will go into metal framing and stay in place fairly well. You can always tape the top of it with duct tape to the top sill channel to make sure it does sag over time. But as a rule that's not done, just saw it once when I was doing the drywall.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 08-05-2005, 05:31 PM   #3
Thanks for the tip.
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 09:23 AM
Black strips on wallboard mounted on metal studs regman Building & Construction 4 07-20-2007 11:07 PM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 05:02 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 07:17 PM
Penetrating Metal Studs gbarron1 Building & Construction 12 03-19-2005 12:13 AM
