Insulating Main Heating Trunk/duct - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-09-2006, 09:39 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
insulating main heating trunk/duct
I have just found out that before I build my soffit, I need to insulate my main heating trunk/duct.
Will they explain at HD how I need to do this, or is there any special tips that I should know about? Do I tape it in place or do I just wrap it around the tunk? For my own curiosity: does this make my heating system run more efficient?
Also, I have 6 inch tubes running inbetween the floor joist, and under them there is wiring running. The builder, on some of them, has put loose insulation between the wires and the duct tube, so that they don't touch.
Is this what I should be doing? Or is there something else that I need to do?
Thanks for any information anyone can provide me.
yummy mummy is offline   Reply With Quote
Old 12-09-2006, 06:10 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi yummy mummy
The only real way to go about what you need to do is to wrap duct wrap around the trunk and runs. The best way to attach it is to staple the seams. If you decide to use foil back duct wrap, after you staple the insulation you can use foil tape and clean up the seams. When you get done its almost a shame to cover it up. As with anything though you know to take your time. The stapler I prefer to use is a Bostich outward clenching stapler. I have one that is almost twenty years old and still works good. If you have any further questions let me know and I will see if I can help.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 12-09-2006, 09:13 PM   #3
carrierman
Thanks for the information.
I guess I can't get away with not doing it? Correct?
I assume the reason is that it provides a vapor barrier so that it will not ruin my drywall in the future?
I know exactly what you mean when you say that you hate to cover your work up.
I am putting so much work into framing and making sure everything is level, etc. (my favourite tools are the level and my chalk line tool) that I told my husband that I hate to cover this work up.
He told me to just take lots of pictures.
I told him that I am going to blow the pictures up and put them all over the walls when I'm done.
Thanks again for the information.
Old 12-10-2006, 12:02 PM   #4
Rewards Points: 502
Hi yummy mummy
When he blows them up, use them for wall paper in your newly finished room. And yes that is all the insulation does, it just creates a thermal break.
Good luck
Rusty
Old 12-10-2006, 03:03 PM   #5
carrierman
Thanks again,
Here I go to HD again.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 04:06 PM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 11:28 AM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 07:17 PM
