Insulating Knee Wall Attic Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 07:35 PM   #1
Insulating Knee wall attic space
I have a bonus room over a garage. The room has a knee wall. Under the knee wall side is a doubled wood beam roughly 12" wide, that runs the legnth of the room and a little beyond. I have spray foamed where the garage ceiling below, meets that beam. I have r-30 on the wall as well. I know I'm getting wind washing because the insulation is dirty in the attic space. The bonus room has a draft on the knee wall side. My question is; Will adding Tyvek help in stopping the air flow into the insulation, and will that help keep out the draft? Also, can I place it snug up to the insulation?
Thanks in advance.
Bloodta is offline   Reply With Quote
Old 12-13-2010, 09:06 PM   #2
Registered User
Rewards Points: 4,924
Yes, Tyvek is acceptable to prevent wind-washing. Be sure to air seal under and over the wall, to keep the wind out of there, snug up to the baffles running on the slope ceiling. The h.w. should go snug against the insulation to prevent convective loops inherent to all low density f.g.blown and batts. http://www.simplesavings.coop/simple...ee%20walls.pdf
Foam board (unfaced) also works though if attic is for storage or inter-connected, it has to be covered- 4.2.1.2: http://building.dow.com/ee/pdf/ESR-2142.pdf
Gary
Old 12-14-2010, 11:00 PM   #3
Gary
Thanks for the reply. You say Tyvek is acceptable, which leads me to believe that there is something better. What would be the best choice?
Old 12-14-2010, 11:48 PM   #4
Registered User
Furr the wall, add cellulose and foam board, ada the drywall: http://www.buildingscience.com/docum...wall-approach/
http://www.buildingscience.com/docum...tlanta-profile
http://www.ornl.gov/cgi-bin/cgiwrap?...le/ins_fact.pl
Gary
Insulating finished attic mudpaws Building & Construction 2 06-30-2012 01:51 AM
Insulating old wall without blower? j. pierce Building & Construction 4 03-09-2010 08:56 PM
Turning Attic Space into Playroom? OneInThree Building & Construction 8 01-08-2010 10:52 PM
How to insulate attic crawl space RISurfer Building & Construction 7 10-01-2009 12:57 PM
Knee wall Ventilation advice needed N8E Roofing/Siding 9 06-29-2008 12:23 AM
