Insulating Interior Walls - Soundproofing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 09:04 AM   #1
Rewards Points: 156
Insulating interior walls - soundproofing
I was thinking of insulating the walls b/t my bedrooms once I build them to help with soundproofing. So, I have a few questions
1. Does fiberglass insulation actually help with soundproofing?
2. Will insulating interior walls have any negative effects in any way? Interrupt airflow from room to room etc.. ?
Branden is offline   Reply With Quote
Old 11-16-2010, 09:37 AM   #2
There are a couple of products you should research, Green Glue and QuietRock. Blown-in or batt insulation doesn't substantially increase the mass of the wall or interfere with the path of the noise, so I don't think it will do much to reduce the noise level. Increasing wall mass and acoustic decoupling are two ways I've seen to effectively sound-proof, which are how the products above function.
Adding insulation to interior walls shouldn't cause problems if the HVAC system is properly designed and keeps the rooms at similar temperatures. Check that the empty wall cavities aren't being used as air-returns to your HVAC. If they are you will need to provide a clear path for the air return if you insulate.
atxjoe is offline   Reply With Quote
Old 11-16-2010, 12:05 PM   #3
Rewards Points: 1,092
Just to add to the above, which is good info, watch for sneaky paths of noise to travel in, like electrical outlets. Apparently FG will cut down on some of the lower frequency sound waves. This was just discussed on greenbuildingadvisor.com, and one of the cats there mentioned that about FG. In general, as mentioned above, add mass.
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Insulating and soundproofing a basement jacads Carpentry 2 03-29-2009 01:50 PM
Insulating and soundproofing a basement jacads Building & Construction 1 03-29-2009 11:10 AM
