Insulating Interior/Exterior Wall Cavity? Old Home From Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 12:07 PM   #1
Rewards Points: 170
Question
Insulating Interior/Exterior Wall Cavity? Old Home from Attic
I was wondering if it is ok to put insulation down the exterior wall cavity from the attic for the 2nd floor of a home?
I just redid all of the attic insulation and cleaned everything up, and I noticed that in some spots on the sides of the home I can see right down the wall cavity between the exterior of the home, and the plaster wall on the interior. The space between the framing seems to go down to about the floor on the second floor area, or just a bit shorter.
Is it ok to put insulation down these cavities? Or must there be some type of ventilation space? Seems like I should be able to put insulation down these areas since that is what is done when a home is framed and insulated.
Can someone confirm if this is ideal? Also, should I be trying to stuff batts or rolls of the pink stuff down, or would it be ok to get the shredded blow type insulation and manually stuff it down the walls from the attic?
Any tips appreciated.
HandyFrank is offline   Reply With Quote
Old 02-04-2011, 04:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,... Absolutely,....
When I did it for my Dad way back when, I stuffed rockwool into 'em, with a stick...
Today,..
I'd thing some sorta Blown-in would be the way to go....
If you've got access, fill 'em up any way ya can, with whatever works for ya...
Old 02-05-2011, 12:05 AM   #3
Registered User
Rewards Points: 5,520
Yes, do it! That is the main problem with balloon framed houses, you have "The stack effect"; http://www.wag-aic.org/1999/WAG_99_baker.pdf
Use a medium density insulation of blow in; either f.g. or cellulose without convective loops; http://www.diychatroom.com/f98/how-b...ulation-90438/
http://www.google.com/url?sa=t&sourc...O842EQ&cad=rja
Gary
Old 02-07-2011, 10:49 AM   #4
Rewards Points: 170
Thanks for the tips guys, and good PDF and links, explains a lot.
Sounds like I will be getting some blow insulation and fill the walls soon
Insulating Attic Conversion Zidden Remodeling 3 02-11-2011 12:42 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Advice for insulating attic kneewall from unfinished side... pasichnyk Building & Construction 10 12-19-2010 07:38 PM
Insulating an attic for finishing Graye2 Building & Construction 2 12-14-2010 10:20 PM
insulating attic walls maverick1096 Building & Construction 5 07-25-2010 01:38 PM
