Old 11-12-2008, 01:00 PM   #1
Default insulating inside the plastic poly pans?
hi - I used the poly "pan" boxes where I have junction boxes in exterior walls - couple questions
1) is the red tuck tape enough to seal the flanges of the pan box to the vapor barrier, or should I add a bead of acoustical sealant to these joints as well?
2) can I use something to fill / insulate the void between the poly box and the outside of the junction box - maybe a soft curing non expanding foam (I think DAP makes something l could use), or stuff in a bit of Roxul scraps, or something like that? I lose about an inch or so of insulating space behind the junction box as the poly pan is oversized a bit compared to the junction box - this is just dead air space
sorry - not sure if this question belongs here or in the electrical forum - thanks
-randy
rtoni is offline   Reply With Quote
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be talking about parts identification. On top here we have our two portable work light heads above our work light heads, we have our cushion grip handles. In the center we have our... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be finishing our project. First off we need to reinstall all of our cables to the wall. Now if you took off the gutter you will have to remember to replace that and secure that to the... Read More »
Moving Electrical Boxes
Moving Electrical Boxes by Expert Village
Were in the process of pulling out the old electrical boxes and were going to move them to the new wall. I have removed this one and here?s the wire hanging here I did shut the power off before I got started in this and they are all these wires are... Read More »
Wakeboard towers add value and style to your boat. Not only are they practical for holding wakeboards, but they are also great for mounting speakers and other accessories. Besides figuring out how to build it yourself, there are several options available... Read More »
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 05:05 PM
Insulating the inside of a flat roof mugwortt Building & Construction 1 12-29-2007 07:13 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
