Old 12-29-2007, 06:40 PM   #1
Default Insulating the inside of a flat roof
I want to increase the insulation value of my roof/ceilings on the main floor of my duplex! Adding more insulation to the exterior/roof dose not incease the insulation value due to the air space between the batt insulation(in contact with the ceilings) and the roof.
I am looking at adding 1 or 2 layers of the foil/bubble wrap or foil/foam to the ceilings inside the unit. I do not want to lower the ceilings too much so thought this was a good way to go but would like to get some more info from people that know more about this kinds thing. The plan is to strap the ceilings afterward and install thin pine tongue and grove for the finished ceiling.
Any thoughts on if the foil/bubble wrap or foil/foam is a good way to go? Or are there better products out there to use?
thanks Dan mugwortt@hotmail.com
mugwortt is offline   Reply With Quote
Old 12-29-2007, 07:13 PM   #2
Building and plumbing
USP45's Avatar
first off the roof needs to breath. If we insulate the roof against the plywood then the roof can not breath. Any condensation will freeze to the bottom of the plywood causing rot and or mold issues. As far as the ceiling goes anything is good. Fiberglass is best in my opinion unless you want to spend some $$$ and have it sprayed with expanding foam.
USP45 is offline   Reply With Quote
More On This Topic
On behalf of expert village, my name is Gregg Tauriello. I'm from suite 16 studio. I'm here to talk to you about soundproofing your recording studio. On this building I have T-111 siding on the outside, which is a standard cardboard siding that you will... Read More »
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
Hi! I’m Tad Donley and I’m speaking in behalf of Expert Village. I’m giving you tips on how to make your own recording studio. Where you have got to set up a studio, where you have got to put it. I am fortunate enough to where I went... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. A knee wall is my I have a change in insulation level in my ceiling. So in other words, my... Read More »
Now I have my other side of my scarf all decorated the way I want it. And I've done one more thing. Which is, I've put my two layers of bubble wrap together on the same side. The trick to this is to have your bubble wrap with the flat sides together and... Read More »
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 08:17 AM
Insulating under part of my Flat Roof Hushpuppy Roofing 5 02-13-2006 04:45 PM
flat roof leak snikda9 Roofing 16 01-26-2006 06:25 PM
Flat Roof 3200sq ft insulating coleimage Roofing 11 01-18-2006 01:17 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-22-2005 12:12 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
