Insulating House With Stone Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2008, 04:56 PM   #1
Insulating house with stone walls
My stone house in SE PA (philly area) has 18 in thick stone walls (2 courses of field/rubble stone). I am re-doing most of the interior rooms which involves removing the plaster walls down to the studs. Of course the house never had any or really needed that badly any insulation; however, i think it would help quite a bit none the less.
What is the proper type and setup for the insulation since the walls are stone - the insulation would have to be stapled to the studs and I guess I would want some vapor barrier between the drywall and the insulation? and the insulation side facing the stone?
On a new, but related note - does anyone have any experience with Barricade Systems by OVRX for basement insulation.
Any help appreciated.
mlupa is offline   Reply With Quote
Old 11-25-2008, 08:36 PM   #2
General Contractor
joasis's Avatar
This would be an ideal application for a spray foam insulation...closed cell, 1 lb. or more, and you will be eternally happy. If cost is an issue, blown cellulose.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 11-26-2008, 05:57 AM   #3
Jill_m is offline   Reply With Quote
Old 11-26-2008, 10:19 PM   #4
General Contractor
joasis's Avatar
Unless the walls are below grade there is no reason for the vapor barrier. Spray foam insulation is a barrier.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Tags
insulation , stone , vapor barrier
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Please HELP me help my mom with her house FORD11 General DIY Discussions 16 04-23-2008 11:24 AM
Repainting a New House 1simple Painting 8 12-10-2007 07:05 AM
