Insulating A Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 11:35 PM   #1
Question
Insulating a garage
So I have a detached garage that I would like to insulate and provide heat / ac to. I would prefer not to finish off the ceiling as I would like to have shelving run up between the rafters for storage.
What is the best way to insulate the building? The spray on foam looks like a great idea, but how does that work with airflow on the roof since it attaches itself directly to the decking (OSB in this case)? I don't want moisture rotting away the roof from lack of airflow.
And on the walls, would I still need to put a vapor barrier / drywall? Or will this insulation be enough to get the job done?
I guess I'm trying to figure out all of my possible options in this situation.
How do roof vents (and attic vents) work if you are heating / cooling the entire space?
Sorry about all of the questions, but it just seems with every Google search, I get a dozen different answers to each question and each answer leads to a whole new question.
indianaftw is offline   Reply With Quote
Old 02-18-2011, 11:56 PM   #2
Registered User
Rewards Points: 5,516
Check with your local Building Department on conditioned roofs; http://www.buildingscience.com/docum...r-all-climates
Where are you located? As to insulation thickness, find your Zone, on map or below in closest city; http://publicecodes.citation.com/ico...001_par001.htm
Then use that Zone for thickness required; http://publicecodes.citation.com/ico..._11_sec002.htm
Rafter insulation required thickness; http://publicecodes.citation.com/ico...006_par003.htm
Foam board and sprayed foam require a fire covering such as 1/2" drywall. The vapor barrier depends on location also; http://www.energysavers.gov/your_hom.../mytopic=11810
Gary
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 12:54 PM
Insulating Garage / Workshop with Free Foam? PaulBob Building & Construction 2 12-05-2008 04:12 PM
Question about insulating a garage forCcanadian winters trucker Building & Construction 3 02-08-2008 05:07 AM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 10:30 AM
