Insulating Floor Over Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 08:14 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Hey friends-
I am in the process of remodeling the first floor of our home which was built in 1907. The picture illustrates insulation installed between the floor joists for a room (that was once a porch from what I can tell) that sits over a crawl space. As you can see, I removed both finish and subfloor down to the joists. As far as insulation goes, I am thinking that I should remove what is there and lay down new batts (I have quite a bit of spare high R-value kraft-faced insulation from another project) with the vapor barrier up (toward the room) and staple the paper to the tops of the joists. The only issue that I see with what is existing is that there are spaces between the batts and the joists. Other than the stains that my own sweat created while removing the original plank subfloor, the insulation looks great (no mold or signs of moisture).
Thoughts?
Thanks in advance for your insight,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-01-2013, 08:28 PM   #2
Roofmaster
Rewards Points: 2,210
Are the joists further than 16 on center? Like 18, as I recall?
Old 04-01-2013, 08:32 PM   #3
Rewards Points: 566
Jagans-
While not consistent, they are typically close to 16" (although they do vary from about 15-1/2 to 16+).
Crawl space insulation question gregsenne Insulation 11 01-16-2013 03:26 PM
Insulating crawl space Cheveldave Insulation 2 11-24-2012 11:34 PM
insulating crawl space rhader Insulation 5 11-07-2012 12:02 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
