Insulating A Floor In The Basement Of A House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 11:20 AM   #1
Question
Insulating a floor in the basement of a house
My brother-in-law has a basement that is heated, but not much, and the rooms upstairs (living, kitchen, etc.) get cold. The flooring is regular wood flooring. He was told by a store (big box store) to use regular insulation between the joists that is wrapped around in plastic, but has holes all through it so it really has no "facing" on it. A friend of his said that was not right and to use faced insulation and he is not sure if he used faced insulation, how to install it. Should the facing go towards the heated part of the structure (up against the flooring upstairs) or should it get attached to the joist, facing down towards the basement with a staple gun. If he puts the facing up against the flooring, what is the best way to keep the insulation from falling down.
Thanks in advance,
Bruce
bstreyle is offline   Reply With Quote
Old 01-25-2010, 04:44 PM   #2
Thanks in advance,
Bruce
Insulation on the floor/ceiling is a waste of time and money!
The basement walls should be insulated!
I'm in the process of insulating my basement walls, right now!
I'm using a product called foundation wrap. It come in rolls that are 4 ft. wide and 50 feet long. And comes attached to a vapour barrier.
The top of this insulation is stapled to the foundation sill plate and the bottom is screwed to the concrete with Tapcon masonry screws.
Old 01-25-2010, 06:07 PM   #3
Registered User
Rewards Points: 526
http://www.advancedenergy.org/buildi...l%20Spaces.pdf
Where are you located for the vapor retarder?
Be safe, Gary
Old 01-25-2010, 07:41 PM   #4
My brother-in-law lives in Connecticut.
Bruce
Old 01-26-2010, 12:42 PM   #5
Rewards Points: 5,336
If the first floor is cold, have him rigid foam board the rim joist and use the foam in a can to fill any gaps.
I see no use of floor insulation in this case.
Ron
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Insulating a basement Snyder-man Building & Construction 27 10-30-2009 11:27 PM
Insulating my basement luweee Building & Construction 9 02-19-2009 08:01 AM
new house old basement abkeeper Building & Construction 5 04-23-2008 05:17 AM
