Old 01-03-2008, 12:15 PM   #1
Insulating floor?
Im working on a renovation and this guy is insisting that we insulate the floor (like rolls of insulation tacked to the joists from underneath)..This is in a cold midwest climate on a 600sq ft house with a crawlspace. To me not only does this seem pointless but possibly detrimental. He is putting the utilities in the attic and rerouting the plumbing, however there is still some plumbing down there that I would worry about freezing lines from the well, etc. Im I off-base here?
Rexkwondo is offline   Reply With Quote
Old 01-03-2008, 12:43 PM   #2
Insulating floor?
You don't have to worry about an unheated basement freezing because it's below grade. (assuming it's not excessively drafty)
You want some insulation between the unheated basement and the heated living space because you will otherwise have 3/4" plywood between your 70 degree living space, and your 45 degree basement. That means cold toes.
NateHanson is offline   Reply With Quote
Old 01-03-2008, 05:47 PM   #3
Insulating floor?
How cold does it get?
redline is offline   Reply With Quote
Old 01-03-2008, 06:54 PM   #4
Insulating floor?
You said a crawlspace, right? How tall is the space?
We have one, too (3 ft.) with plumbing in it. We have insulated the walls in the crawlspace and put vapor barrier on the floor and walls. It has been staying 60 degrees down there... and it's freezing outside...
leezarrd is offline   Reply With Quote
Old 01-04-2008, 07:26 AM   #5
Insulating floor?
Alright then, I guess we'll do it. Any ideas on how to make this go as efficiently as possible? The only thing I can think of is to tack up some rolls from underneath..doesnt sound fun
Old 01-04-2008, 09:48 AM   #6
Insulating floor?
Did I miss something? Why have you decided to insulate your floor? Are you unconcerned about the plumbing underneath?
Here is some info that might interest you...
http://www.aecc.com/doug-ryes-tips/c...icle.asp?ID=51
Old 01-04-2008, 10:21 AM   #7
Insulating floor?
Here's another link about insulating crawlspaces. http://www.ecark.org/doug-ryes-tips/...icle.asp?ID=50
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Insulating Exposed Floor batou General Discussion 2 12-08-2007 11:04 PM
insulating under first floor NateHanson Building & Construction 19 11-30-2007 11:09 AM
