Insulating Exterior Walls: House Built 1956 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 12:59 PM   #1
Hi everyone,
Its getting to be that time of year again. Purchased the house last fall and we had a pretty cold winter in WI. The problem I have is that the exterior walls are very cold to the touch. From what I can tell the only thing for insulation is 5/8" of the dense brown fiber type sheathing.
What can I do short of drilling holes on the outside or inside to make them warmer? Should I focus trying to get everything as warm as possible first? I just installed new windows and doors, so that is covered.
whiteblur is offline   Reply With Quote
Old 09-23-2010, 01:57 PM   #2
I've been slowly working on updating the insulation in my 50's house
I added a small insulated 3 season porch on the front
Gutted 2 closets on exterior walls & added insulation
Added a sunroom off the back
Also added a 1/2 wall along the front w/R22
Just gutted my sons bedroom & installed R13
I have one wall left in the Master bedroom, 2' wall in a closet
Then a small section in the middle bedroom
You will either need to drill holes & do blown in (not my preference)
Add rigid on the outside if you will be residing
Or open the walls & add insulation
Old 09-27-2010, 04:04 PM   #3
What exactly do you mean by a half wall?
Old 09-27-2010, 08:04 PM   #4
1/2 wall along the front that wrapped around to the side
Front has R22, side full wall has R32
Also on the left side of the pic I opened up the wall & installed R13
During:
After, still need to reside the top & finish a few areas
Old 09-27-2010, 08:11 PM   #5
I think that was a really good idea and looks good on top of it. Nice job!
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 05:58 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
cracked foundation on a new built house wilddngy Building & Construction 2 05-06-2006 09:56 AM
