Insulating An Existing Finished Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 10:36 AM   #1
Cool
Insulating an existing finished basement
Hello Everybody,
I am currently looking to turn my partially finished basement into a usable everyday area. The basement currently has furring strips and then drywall over the CMU block wall...NO insulation. The finishing job on the drywall is pretty good so I would hate to rip out the sheetrock and have to frame and insulate. I have a very dry basement. Does anybody have any suggestions for adding insulation without removing sheetrock? Could I possibly blow in insulation by removing base molding and blowing through the gaps between furring strips? Thanks so much.
Jason
jman0505 is offline   Reply With Quote
Old 02-20-2011, 04:06 PM   #2
Rewards Points: 1,092
As best as I can gather, blown in cellulose or fiberglass are not the best choices for your app. Sorry to tell you, but if you are going to insulate, nuke the drywall and install either rigid foam on the wall, rock wool between the studs, or both. Check on buildingscience.com
Old 02-20-2011, 08:53 PM   #3
I can tie my own shoes
algored2deth's Avatar
One option may be spray foam.
Check out:
Tiger Foam™ 600 bd. ft. Kit - SR here
http://www.tigerfoam.com/products.php
This will be pretty pricey in comparison to other methods. When it comes to basements, you can pretty much stick with XPS foam and spray polyurethane foam.
algored2deth is offline   Reply With Quote
Old 02-21-2011, 09:28 AM   #4
Thanks for the responses guys. I will most likely rip out the sheetrock and insulate with foam board.
Old 02-21-2011, 09:33 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
What about your outlets and switches?
The most common method of finishing basements is to frame a 2x4 wall set 1" away from the foundation.
This method makes insulation, electrical and drywall much much easier and a better bang for your buck.
tcleve4911 is offline   Reply With Quote
Old 02-21-2011, 12:32 PM   #6
1" rigid foam sandwich. Just another alternative
mrgins is offline   Reply With Quote
Old 02-21-2011, 07:01 PM   #7
I used to think the same thing, but after a lot of digging I am finding that EPS actually works a bit better than XPS. EPS is being used sub-grade extensively. So, either one, in a basement, should work fine. EPS is cheaper. (EPS is "white board", for those not into acronyms.
Old 02-22-2011, 11:10 AM   #8
Here is a review of different foam materials.
http://www.finehomebuilding.com/item...hould-i-choose
Another link to read:
http://www.greenbuildingadvisor.com/...oam-insulation
I have seen some basement remodels done with EPS. From what the above link says, it appears to not be a good enough vapor barrier on its own. I have no direct experience with EPS so I cannot comment on it directly. It may work just fine.
dennis
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 04:30 PM
tapping into existing HVAC for basement denemante HVAC 3 10-27-2010 05:12 AM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
Transforming a finished basement into a bedroom suite drlsubaru Remodeling 28 07-08-2009 02:35 PM
Finished Basement Quandry SonOfPirate Remodeling 5 04-29-2008 04:23 PM
