Insulating Exhisting Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 12:19 PM   #1
Unhappy
Insulating Existing Basement Wall
Hello,
My house is a 2 year old split level. The basement was finished as part of the agreement with the contractor. The agreement said to finish the basement with the same quality materials as the rest of the house. The stupid realtor said I didn't need to say insulate , that would be implied. Well aparently the contractor did not insulate the lower 44" of the basement wall (Pretty mad and just discovered it now that we started using that room more). The basement is poured concrete 44" up to grade and the rest is 2x6s. From what I can tell he framed the lower half out with 2x4s and put them 1/2" off the cement wall. So there is a "shelf" going around the room on 3 sides. The problem is that it is drafty in the winter time. I guess there are two options:
Closed Cell Polyurathane foam, which with 170 square feet @ 4" deep would cost me $1000. Plus even with a slow rise formula there is the risk of blowing out the drywall.
The other option is to cut a strip of drywall out (~24") midway and use 1/2" expanded polystyrene, tapes seams with Tyvex tape, and then use 3.5" R13 fiberglass to finish. Then put new drywall up, tape, mud, and paint (lots of work). Would it just be easier to take all the lower drywall out instead?
Anyone has any other suggestions?
soasquad is offline   Reply With Quote
Old 01-09-2010, 01:48 PM   #2
Remodeling Contractor
open cell spray foam will air seal and insulate the void and not blow out the drywall as well is fill in around wires and outlets better. And cost less. But will yield less R-Value/Inch, but you most likely we still be better off.
Old 01-09-2010, 10:11 PM   #3
Yea but an open cell foam won't serve as a good vapor retarder... right?
I live in Nebraska by the way.
Old 01-10-2010, 06:56 AM   #4
Correct.. Used in rafters you do not need venting thus no cold air space to deal with. But you do need a continuous vapor barrier. (IE poly)
Basement Wall Project flati General DIY Discussions 16 01-04-2010 09:26 AM
Interior Basement Wall finishing tookie Building & Construction 0 01-01-2010 04:04 PM
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 09:57 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 09:54 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
