Insulating A Daylight Basement With RMAX - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 05:16 PM   #1
Rewards Points: 87
Insulating a daylight basement with RMAX
I am starting the process of finishing the lower unfinished level of my house starting with furring out the cinderblock walls for insulation.
Below is my model of how I am thinking of building the wall based off of the RMAX specs.
RMax Install:
My design:
This is basically the same as the RMax install but with an additional stud wall and layer of RMax after the thermal break to hold plumbing and electrical.
I have a couple questions such as...
1. I don't really want to use Treated wood inside the house. Could I use something like Cedar instea for my furring strips if not also my stud wall.?
2. Does my electrical need to be in conduit inside RMax?
3. Should I connect the sections of my air gap between the cinderblock wall and the thermal break to assist air flow?
4. Do I need the secondary air gap I placed between the layers of RMax?
Any suggests or pointers on anything I am doing wrong or would be better off doing a different way are much appreciated.
hellonoko is offline   Reply With Quote
Old 01-09-2012, 04:19 PM   #2
Remodeling Contractor
Just use doug fir and use sill insulation behind it. Actually works better. Since water will still wick through pressure treated lumber by capillary action
No
The air gap is to vent any moisture trapped behind the wall. It should be continuous from the floor to the ceiling joist bays
no
The best way to frame a basement wall is to leave the framing 1" away from the wall. Now spray foam 2" closed cell foam behind and between the studs. Now you have a stronger wall that will not have a moisture problem internally.
Old 01-09-2012, 09:34 PM   #3
Registered User
Rewards Points: 5,498
Fire-block the floor joist cavities above from the walls below and walls every 10', per minimum code; http://publicecodes.citation.com/ico...002_par031.htm
You don't want any air to the concrete wall/foam board; http://www.buildingscience.com/docum...lation-systems
Foam board directly attached to the block, no air gap, or gap at insulations for c.l.'s; http://joneakes.com/jons-fixit-database/743
Don't use a poly-faced or foil-faced board as R-max; http://www.buildingscience.com/docum...ts?full_view=1
Air-seal/canned foam the rims first; http://www.buildingscience.com/docum...-at-rim-joist/
Air-seal the drywall; http://www.buildingscience.com/docum...wall-approach/
Where are you located for thickness of foam?
Gary
Old 01-10-2012, 12:16 AM   #4
Rewards Points: 87
I am located in Southern Oregon
Old 01-10-2012, 07:24 AM   #5
I have done a number of basements using XPS(extruded polystryene) foam, glued to the walls, then furring strips over the foam, with tapcons into the block. That holds the foam tight and provides for hanging drywall. 2" XPS=R-10. Moisture won't penetrate the XPS, and since the wood does not touch the block, no need for PT.
Old 01-11-2012, 11:26 PM   #6
Rewards Points: 87
@Gary for all that info!
Thanks for the replies I had a couple more questions:
1. Is Foamular 150 a suitable XPS rigid foam to use for this application? Is there any issue with double layering it, say two sheets of 2" giving me R-20?
2. What material do I use for a capillary break under my framed wall?
3. Is this wall paint an issue?
4. My rim joist are non typical / non existent? (The cinder block turns into some type of decorative block that goes all the way up:
5.Can I continue the rigid foam all the way to the subfloor? How do I fire block this correctly?
Thanks for all the help!
Old 01-12-2012, 05:28 PM   #7
Registered User
The Foamular 150 is fine.
A poly sill sealer will act as a thermal/capillary/air break under a cedar sill plate. The warmed wall (with a sealer) won’t cause the slab (touching earth) to act as a “heat sink”. It will stop any moisture coming up to wet your wall studs; http://www.greenbuildingadvisor.com/...-building-code And it will seal the gap under the wall from basement air reaching/condensing on the colder concrete block wall behind the foamboard (if not 100% sealed). Tape the board seams, canned foam the bottom and joints abutting the fire-stopping studs/material every 10’ lineally. Two layers of board are fine. The top plates of the wall (and the foam board) need to stop any wall cavity fire from reaching the floor cavities above. Best: How to fireblock framing
The paint may not be an issue, be sure all outside drainage is proper. Earth sloped away from house, down-spouts extended, etc.
http://www.lowes.com/pd_13280-46086-108942_4294858107__?productId=3363030&Ns=p_product _prd_lis_ord_nbr|0||p_product_qty_sales_dollar|1&p l=1&currentURL=%2Fpl_Insulation%2BAccessories_4294 858107__%3FNs%3Dp_product_prd_lis_ord_nbr|0||p_pro duct_qty_sales_dollar|1&facetInfo=
Cedar will substitute, check with your local building department, need the permit for H.O. Insurance paper trail, anyway. “Naturally durable wood”: http://publicecodes.citation.com/ico...9_3_sec017.htm
Cedar fits: “NATURALLY DURABLE WOOD. The heartwood of the following species with the exception that an occasional piece with corner sapwood is permitted if 90 percent or more of the width of each side on which it occurs is heartwood.
Decay resistant. Redwood, cedar, black locust and black walnut.
“ from: http://publicecodes.citation.com/ico...9_2_sec002.htm
On top the foamboard: http://publicecodes.citation.com/ico...002_par032.htm
Gary
Old 01-15-2012, 07:20 PM   #8
Rewards Points: 87
Gary thanks for all the help.
I have read over pretty much all of that and understand the how and why. I am currently test gluing a piece of Foamular to my painted wall. The glue says it is not recommended for walls with paint but it seems to be holding ok.
The only think I am not exactly clear on is the fireblocking method.
I have read through the very good post on here and made another diagram..
Which of these ways do I need to install to properly fireblock? (I also posted this is the fireblocking thread)
Do I need to block the top of the foam board as I have done on the left?
Old 01-16-2012, 04:20 PM   #9
Registered User
The left side is correct, blocking the wall cavities from the above floor/ceiling cavities in case an outlet shorts/sparks to start a fire. This would limit it to the 10' wide section of wall only.
I would slip some Grace I&W shield behind the joist ends, if not tight to the block for a capillary break there, bigger gap-use sill sealer. You need a stud with Grace on the edge, every 10', sistered next to a layout stud for wall fire-stop. Use sill sealer between the studs for thermal break as the f.s. one is touching cold blocks-through the membrane (heat-sink). Foam board installs between the vertical sistered studs. Notch longer studs or add small wood pieces with Grace at the plate areas to fire-stop.
Gary
Old 01-16-2012, 04:38 PM   #10
Rewards Points: 87
Thanks again Gary,
Does this mean I only have to fireblock once every 10'? Wouldn't it be best to put a fireblock in every joist space?
What is Grace I&W? I don't think I can access the joist ends. But I will take a look at it.
If I am reading this correctly. I want a double stud every 10' horizontally to act as a horizontal fire stop incase a potential fire moved horizontally between studs? Or are you referring to the top plate area?
This would be a sandwich of my Foamular and two studs then?
Old 01-16-2012, 05:28 PM   #11
Registered User
Fire-block top continuously.
F.b. studs every 10' apart. Foam board between them. The stud f.b.(from wall stud to CBU - no foam for a sandwitch) has to stop fire between cavities. F.b. is not fire-block, only: http://publicecodes.citation.com/ico...002_par032.htm
http://publicecodes.citation.com/ico...002_par033.htm
http://publicecodes.citation.com/ico...002_par034.htm
I don't recommend putting fiberglass or mineral wool directly on wet blocks for fire-stopping, hence the extra stud every 10' across the length of the wall.
If I am reading this correctly. I want a double stud every 10' horizontally to act as a horizontal fire stop incase a potential fire moved horizontally between studs?---- correct.
You cannot have foamboard between the f.s. stud and the CMU. It could melt and lose the integrity of the 10' section of wall.
Grace I&W is a stick poly/bitumen coated weather seal material, any window/door sticky wrap will work.
Gary
Old 01-16-2012, 05:34 PM   #12
Registered User
Fig. 21, 22, on page 2: How to fireblock framing
Gary
Old 01-16-2012, 06:11 PM   #13
Rewards Points: 87
So I need to interrupt my Foamular thermal barrier every 10' with a horizontal fireblock stud? Won't this create a thermal bridge to my framed wall?
Old 01-16-2012, 06:57 PM   #14
Registered User
Correct. The 1-1/2" wide stud edge with the sticky wrap will create a thermal break. To offset it from acting as a heat sink (warming the studs with conditioned air transferring by conduction to the CMU), by sill sealer between the fire-stop stud side and the regular stud side. The 1-1/2" will be a thermal short in the foamboard, ask your Inspector if it can be installed continuously, as Formular with sleeper wood at the 2' joints.
Gary
Old 01-16-2012, 09:40 PM   #15
Rewards Points: 87
Alright,
Thanks for all the help I will talk to the city now that I know how it should be done and see exactly what they require!
Thanks again.
Tags
basement , insulation , thermal break
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 06:19 AM
Do I need to add HVAC ducts to my below grade basement rooms if my daylight basement rooms already have HVAC supplies and returns? cmgoss HVAC 1 06-29-2011 05:12 PM
Insulating interior basement walls brazzle Insulation 3 05-04-2011 07:24 PM
