Old 09-02-2008, 10:53 PM   #1
Insulating a daylight basement
Greetings
I'm shopping around for insulation and I'm hoping I can get some advice. Center to center is 16 inches but from top to bottom it's 98 inches. I was looking at Batts insulation (R15) with both sides covered with some sort of vapor barrier. However all the sizes are 93 inches in height.
My question is; Is it better to get the 93 inch height batts and make cuts to add the remainder 5 inches of need insulation or are there long rolls of Batts that I can just cut at exactly 98 inches?
Is the vapor barrier that is included on these batts sufficient, even if I have to make cuts? It just seems to me that adding multiple pieces between the studs will weaken the effect of the vapor barrier because it's not continuous.
steve31 is offline   Reply With Quote
Old 09-02-2008, 11:07 PM   #2
Interesting-Found this on the Insulation Contractors Association of America website. Unless I'm reading it wrong, they state that putting a vapor barrier insulation below grade is not recommended.
Below-grade basement walls differ from above-grade walls in that they are vulnerable to ground
moisture wicking into the wall or basement floor. Because of this, it is important to maintain the
drying potential of the wall since one never knows if the long-term moisture drive will be from
the outside or the inside . A masonry wall is capable of absorbing large quantities of water due to
the capillary action of concrete . If the masonry wall unit has hollow cores, air movements within
the wall also increase the thermal and moisture movement . For this reason, it is recommended
that a vapor retarder not be used in a wall that is partially or fully below grade . If a wall is above
grade, such as in a walk-out basement, then that wall may use a vapor retarder, if the climate
dictates a vapor retarder in above-grade walls .
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 09:54 AM
Insulating a daylight basement steve31 Building & Construction 3 08-22-2008 03:33 PM
Insulating basement windows Keyo77 General Discussion 3 01-06-2008 07:33 PM
Insulating basement ceiling? pastfast125 General Discussion 2 03-30-2007 07:14 AM
Insulating a unfiinshed basement govikes Building & Construction 7 03-26-2007 05:55 PM
