Old 08-21-2008, 06:52 PM   #1
Insulating a daylight basement
Greetings,
I live in the PacNW and our house has a daylight basement. The basement is framed in already and is ready for insulation. I'm not sure what the best methods are for this task. Against the concrete walls it's approx 5-6 inches deep between the studs.
Against the walls without concrete (above walls) I assume I can just use batts insulation. Correct?
What practices should I use against the concrete walls? Is it better to use polystyrene foam or batts? I assume a vapor barrier will be required is requierd? Does the vapor barrier go on the inside over the studs/insulation?
Thanks for your time.
steve31 is offline   Reply With Quote
Old 08-21-2008, 10:14 PM   #2
Moderator
Termite's Avatar
Some people put a poly moisture barrier between the studs/insulation and the concrete wall. The kraft facing on the insulation is a vapor barrier itself. It can be argued that two vapor barriers can create a dead spot in the wall between them that doesn't breathe.
I'm a fan of using foamboard against the foundation wall behind the framing, and conventionally insulating the wall cavity with kraft faced fiberglass batts (no poly vapor barrier).
Old 08-22-2008, 12:15 PM   #3
Thanks for the reply.
Do you put the foam board right against the wall? How do you fasten the foam? What is the kraft face?
Old 08-22-2008, 03:33 PM   #4
Moderator
Termite's Avatar
Kraft face is like a brown paper grocery sack. It comes on batt insulation.
I wouldn't worry about "fastening" the foamboard to the wall. No point in it. Use spray foam like Great Stuff to seal gaps and such...The spray foam will also do a heck of a job securing the foamboard.
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 09:54 AM
insulating a basement ceiling for sound JHill Building & Construction 15 02-27-2008 09:04 PM
Insulating basement windows Keyo77 General Discussion 3 01-06-2008 07:33 PM
Insulating a unfiinshed basement govikes Building & Construction 7 03-26-2007 05:55 PM
Insulating old basement kphilbeck General Discussion 1 11-11-2006 03:29 PM
