Insulating Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 08:56 AM   #1
Insulating crawl space
We are converting our seasonal cabin to a year round. At least we want to be able to use it in the winter when we can. The crawl space is not insulated. We'll be putting down poly on the dirt floor, and insulating the walls. They currently have 1"pink foam insulation between the studs.
It's a small space. 20' X 22' total. 2' high on one end sloping to 4' on the other. Our plumbing is down there. Plan on putting a heater down there, as well as a dehumidifier. We will drain the water when we won't be there for a few weeks between visits.
For a space like this how much insulation should I put in the short walls? They're just 2 X 4 walls.
macminn18 is offline   Reply With Quote
Old 10-07-2010, 10:28 AM   #2
Rewards Points: 5,336
I'd fill them with foamboard, maybe a layer on top of the studs. But if you use any foam product, you need to sheetrock over the top so the foam is covered.
Ron
Old 10-07-2010, 03:32 PM   #3
Registered User
Rewards Points: 526
"For a space like this how much insulation should I put in the short walls?" ----- there is a cost/R-value with insulation: http://www.enersavesystems.com/pdf/E...Insulation.pdf
If you go to a "closed" crawl, check with your local B.D. for radon and air exchange requirements: http://energy.cr.usgs.gov/radon/rnus.html
http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
If in a cold climate: http://www.eere.energy.gov/buildings...s/db/35379.pdf
Gary
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
Insulating split level home crawl space. sithappens Building & Construction 1 02-29-2008 09:47 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
