Insulating Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 01:26 PM   #1
Question
Insulating crawl space
What is the best way to insulate the crawl? I have a similar situation and I was considering using foil backed plywood as an underlayment (foil side down) or draping a foil bubble wrap in the joist space above the fiberglass batts. Does anyone have any suggestions or better ideas?
src9991 is offline   Reply With Quote
Old 09-24-2009, 11:47 PM   #2
Registered User
Rewards Points: 526
The v.b. should be on the ground, 6mil. minimum, overlapped and taped a little up the concrete side walls. Un-faced batts in joist space held up with string or wires.
Be safe, Gary
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
Insulating split level home crawl space. sithappens Building & Construction 1 02-29-2008 09:47 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
