Insulating Converted Garage/room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 10:06 PM   #1
insulating converted garage/room
I am taking the paneling off a room that was an attached garage converted to a room. The walls are 2X4, but then they have 3/4 inch cork like material between the studs and the outer wall. It's not exactly cork. The material is mostly between the outer wall and the studs. So in many places I could place another 3/4" of insulation. Initially I was going to go with the R13 faced batts for 2X4 walls, but I could fit in a little more insulation, but the R19 faced batts are for 2X6 walls so the insulation would be compressed.
Any suggestions what I should put up? Just stay with the R13?
oscarMadison is offline   Reply With Quote
Old 02-02-2009, 10:14 PM   #2
R19 compressed into a 2x4 wall will give you R13
Stick with R-13 or R-15 - made for a 2x4 wall
Compressing insulation reduces its RValue
Old 02-03-2009, 07:00 AM   #3
That's kind of what I was thinking, just hated to not make best use of the areas that are basically 2X5.
Old 02-03-2009, 01:22 PM   #4
I'd go with R15 then
It will give you a better R value then the compressed R19
If you want buy some rigid foam board & fill the extra inch
Some people also "peel" fiberglass insulation thinner & use that to fill in
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
Insulating a converted porch pjm Building & Construction 4 10-28-2008 11:45 AM
Question about insulating a garage forCcanadian winters trucker Building & Construction 3 02-08-2008 05:07 AM
Insulating A/C ducting ? Scott_K HVAC 1 10-04-2007 06:21 PM
