-   -   Insulating a concrete floor>>> (http://www.diychatroom.com/f19/insulating-concrete-floor-32148/)
mikebmore 11-18-2008 04:21 PM
Hello all..i have a one car garage that has 3 walls of cinder block and a ceiling that is concrete..above the garage is my family room and on top of the cocrete floor is padding and a rug..however it is cold...can i put rigid insulation panels on the garage ceiling to help??? if so any ideas how to attach...if not anyone have any other ideas????????
thank
mike
Wildie 11-18-2008 07:03 PM
thank
mike
Glue styrofoam panels to the concrete ceiling! Unless of course your building code requires strofoam to be covered with drywall.
In this case, you could fasten metal framing studs to the concrete, insulate between them and the place drywall over top ( or rather underneath)
Marvin Gardens 11-18-2008 07:47 PM
Anywhere concrete meets cold air you will have to insulate.
What you might consider is hydronic heating. Run some pex from your water heater and add a circulation pump. Then cover the pex with rigid insulation and you will want to lay down on the floor it will be so warm.
