Insulating Ceiling In Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 03:27 PM   #1
Insulating ceiling in garage
I am finishing my two car garage......walls are already insulated, and also added more ceiling joists to attach drywall. I don't want to turn the extra space at the top into an attic.
Can I add insulation between the ceiling joist and just attach drywall (close the ceiling off)? Mind you I don't hav any soffit vents......I wasn't sure if that area needs air circulation.
Not sure if the pictures help......any feedback is good :-)
Jaosnh is offline   Reply With Quote
Old 10-26-2011, 05:40 PM   #2
Rewards Points: 5,336
Before addressing the insulation, I'd like to ask, if those are splice plates connecting the butt ends of 2x4"(6)s?
If it is, that's not a good idea at all. Two words, ceiling collapse.
You're spanning too far with the 2x4"(6)s anyway. Even if it were one piece.
How far is the span?
Once you get the correct framing, you can just insulate the ceiling joists.
The loft area should have a vent system to keep the super heated air from driving through the insulation into the lower area.
Ron
B. Franklin 1759
Old 10-27-2011, 04:46 PM   #3
Ok thanks....taking care of the framing now. When u mean vent system, soffit vents? I don't want to use the top space at all, whole ceiling drywalled and closed off.
Old 10-27-2011, 06:14 PM   #4
Busy DIYer
picflight's Avatar
Rewards Points: 150
You should still vent the space above the ceiling.
picflight is offline   Reply With Quote
Old 10-27-2011, 10:41 PM   #5
You vent the space for a number of reasons, whether you use the space or not. One reason was the one previously mentioned. Others include that a cooler space will place less stress on builing materials like the roof and the sheathing it's nailed into.
You didn't answer the butt splice question.
Ron
B. Franklin 1759
Old 10-27-2011, 11:26 PM   #6
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Here is video on the questions that Ron and others have on your garage venting, framing insulation issue.
I hope this helps.
Andy.
AndyGump is offline   Reply With Quote
Old 10-28-2011, 04:38 AM   #7
Yes they are 2 by 4's connected with plates on each side with nails. They aren't spanning the whole length of the garage, just half. There was already a wood beam splitting the garage in half, so I added 2 by 4's on each side. Where the two studs meet with the splice plate I do plan on connecting a 2 by 4 to the roof rafters. I live in the Pittsburgh area, so temperatures stay between 30-90's
Old 10-28-2011, 07:37 AM   #8
That framing detail is a mistake. Any load put on the rafters above will not hold up. You may not put anything up there, but future owners might. Even if you don't, the load of the sheetrock and insulation could cause it to fail.
This is a classic homeowner mistake, doing things on the cheap to save money. It will bite you on the ass in the long run.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
AndyGump (10-28-2011)
Old 10-28-2011, 10:12 AM   #9
I understand.....what would you suggest on framing?
Old 10-28-2011, 02:39 PM   #10
AndyGump's Avatar
Rewards Points: 664
Insulate the rafters.
Andy.
Old 10-28-2011, 11:46 PM   #11
Registered User
Rewards Points: 5,266
Your location may not need ventilation: http://www.fpl.fs.fed.us/documnts/pdf2002/rose02a.pdf
On the other hand, attic ventilation and access is required per code if this will be “living space”: http://publicecodes.citation.com/ico...9_8_sec006.htm
Read the other ones, clicking on “next section” at that site.
Access is required: http://publicecodes.citation.com/ico...9_8_sec007.htm
Ceiling joist spans: http://publicecodes.citation.com/ico...002_par023.htm
What is the end purpose of the garage finishing?
Gary
Old 10-29-2011, 12:01 AM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
On those ceiling joint splices....I believe the 'typical' standard is 4' to either side of the splice....hence, you would need to sister up an 8' length of lumber across each splice.
What is the span? Over 18'? Confirm those are 2x4's? If so.....then I'm thinking you want 2x6's at a min...if not 2x8's....even for ceiling joists.....like Ron said....your existing setup is not going to hold any weight....
Garage ManCave Please Help!!! ManCaveMark Building & Construction 7 09-14-2011 04:01 PM
garage ceiling moisture chezseans General DIY Discussions 4 02-08-2010 03:35 PM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 03:46 PM
Garage Ceiling CCarlson Carpentry 7 10-05-2008 06:25 PM
insulating a garage ceiling, a bit different question scooterw Building & Construction 1 09-15-2008 10:45 PM
