Insulating The Ceiling Below A Flat Roof Question? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 04:10 PM   #1
Cool
Insulating the Ceiling below a Flat roof question?
In the Ceiling, The original work was very tight and professional.
They DID NOT insulate a "6 section that overhangs past the walls.
We have a new flat roof and gutters(which were NEVER there before AFIK).
We are repairing the damage from the old leaky roof.
I feel I should have insulation there now. Any thoughts on why it was not done before? Should I not for any reason?
Throy is offline   Reply With Quote
Old 09-23-2009, 04:17 PM   #2
Cool
PS - These Channels are full of wind. I can see easily how they can be sealed from outside.
Advice appreciated.
Cheers.
Old 09-24-2009, 06:50 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
There is no reason to insulate the overhang. It will do nothing to increase comfort or lower energy costs, since it is beyond the living space. In most cases it is not even a good idea, since the overhang serves as part of the roof system ventilation. Since flat roofs are harder to ventilate than higher slope designs, you do not want to impede any venting that is present by closing it off with insulation. Any airflow across the underside of the roof surface is removing moisture that could condense there.
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
Ceiling Insulation question racerdad Remodeling 6 04-11-2008 03:14 PM
Flat roof rsteve12 Roofing/Siding 2 10-23-2005 11:27 AM
Flat Roof Suggestion gladiator Roofing/Siding 3 09-14-2005 03:31 PM
