Insulating Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 10:21 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Insulating ceiling
I've got my house down to studs and am going to be adding insulation (attic floor). The attic is non-livable space.
The ceiling joists are 2x6.
My plan is to glue and screw a 2x sleeper on edge on top of these then add a subfloor for the attic. The sleeper and the 2x6 would give me space for 9" of pink.
I'm not sure I'm going to add subfloor to the entire attic space but I do want some dead or seasonal storage space up there (maybe 6 or 8 sheets worth).
Is this the way to go about this?
The other option is to pull out the 2x6s and replace with 2x10s. That seems wasteful and more costly.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-16-2011, 10:37 AM   #2
Rewards Points: 5,336
Plan A makes sense.
Ron
Old 01-16-2011, 10:43 AM   #3
Rewards Points: 6,652
2x10's would be great if you are going to make the space habitable later on.
Old 01-16-2011, 12:01 PM   #4
I have gas!
Thanks guys, I just wanted to make sure.
Unless I raise the roof, this space can never be anything but storage.
Old 01-16-2011, 12:30 PM   #5
Experienced
Jackofall1's Avatar
Plan "A" sounds good, but, you might want to do some research as what kind of material you are going to use for vapor barrier and insulation. There are other and better options than pink.
http://www.buildingscience.com/searc...ing+insulation
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Insulating a cathedral ceiling...please help mklang Building & Construction 8 09-23-2010 02:28 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
