Insulating Cathedral Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 10:50 AM   #1
I am remodeling our garage which is heated and air conditioned. I want to reinsulate the ceiling and install vents to stop condensation from forming. The roof construction is 2 x 6 rafters, can I use Owens Corning Foamular F-150 2" thick? Must I leave a 1" to 2" air space between the foam and the plywood roof and install roof vents? Which roof vents work the best? How many vents? Garage size 22' x 32'. The ceiling will be vaulted and sheet rocked. Location: Minnesota.Thank you.
langseth is offline   Reply With Quote
Old 03-02-2012, 11:03 AM   #2
Rewards Points: 14,306
It would be best to go back and edit your profile and addd where you live so we can ansewer your question.
http://www.energystar.gov/index.cfm?...sulation_table
Your going to need soffit venting, foam baffles, ridge venting.
2 X 6 rafters will not give you enough room for much insulation. It may be best to at least add 2 X 2 straping to the bottom of the joist so you could at least get R-19 in there.
It's often better to have the bays spray foamed, or insulate the roof as well as the ceiling to give you the total insulation you need.
langseth (03-02-2012)
1.5 Story Cathedral Ceiling Support seanmsweeney Building & Construction 4 09-21-2011 03:39 PM
Condensation inside ceiling of cathedral ceiling HandyDaddy Roofing/Siding 5 07-24-2011 02:17 PM
Insulating a Cathedral ceiling in California wolfsden Building & Construction 9 02-16-2010 12:46 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
