-   -   insulating cathedral ceiling (http://www.diychatroom.com/f19/insulating-cathedral-ceiling-122520/)
South Branch Ca 11-06-2011 06:04 AM
Hi all,
Insulating new construction cathedral ceiling and have already installed fiberglass batts R-38 (which is all I had room for) with air baffle in the ceiling. Seems as thou everybody you talk to has a different opinion on how to insulate cathedral ceilings. I'm not going into all the details and the why, but that part is done. But had the contractor stop by, to look at the job to install Nu Wool insulation in the walls. In conversation I mentioned that we were putting tongue and groove cedar on the walls and ceiling. He asked if we were putting dry wall underneath, I said no. His recommendation was to put dry wall or 1" of styrofoam underneath and tape the joints. His point was that the tongue and groove cedar would allow air to move through the walls and ceiling thus we wouldn't be happy with the fiberglass as an insulation. And have high heat loss. If this is true could I just put up plastic and accomplish the same thing which would limit air movement through the cedar?
woodworkbykirk 11-06-2011 07:41 AM
the other thing the contractor forgot to mention is that the drywall is needed for fire protection.. the drywall will slow down the movement of smoke and fire.
ive done the same thing your doing a few times on houses ive renovated. we had to hang drywall first and give it one coat of mud
