Insulating A Cape Cod - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2007, 02:40 PM   #1
Insulating a Cape Cod
Ok, I am looking to add some R value to my cape cod. The problem is that the rooms are insulated from the inside, not from the attic side. I am going to add some insulation to the floor on the outside, but the backside of the interior wall is just bare insulation, what can I use to further insulate this, or at least block some of the air that will flow through from proper ventilation?
x2thez is offline   Reply With Quote
Old 09-14-2007, 07:43 PM   #2
Reside using Tyvek and a fanfold insulation.
jiggyjack is offline   Reply With Quote
Old 09-14-2007, 11:04 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
I would remove the old,install raftermate continuosly for proper breathing,then have a contractor install spray foam insulation to the back of the raftermate,a couple inches(R-7 PER ")Then install fiberglass for the rest of the space w/paper facing you can fold onto the rafters and staple--then install the sheetrock,here`s some pics of what happened to a house w/not enough fiberglass insulation,and plastis(like tyvek)installed to the beams before sheetrocking it,all the water stains are from condensation problems w/this system Good luck!
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Insulating A/C ducting ? Scott_K HVAC 1 10-04-2007 06:21 PM
? about 70's cape and how to open rooms angelonbreak Remodeling 3 04-25-2007 07:59 AM
Best setup for cape cod walker45 HVAC 2 12-06-2006 05:20 PM
Insulating duct run in vented crawlspace Magus HVAC 2 11-29-2006 03:09 PM
Insulating an attic for HVAC system BigJimmy Building & Construction 7 10-07-2006 09:10 PM
