Insulating Cabin - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 05:49 PM   #1
Insulating cabin
I would like to insultate underneath our pier and beam cabin. Does the vapor barrier of the insulation go towards the subfloor? Would it be a good idea after the insulation is in place to staple plastic to the joists and also put plastic on the ground.
Any thoughts
Greg
Dusty522 is offline   Reply With Quote
Old 08-19-2011, 07:56 AM   #2
Rewards Points: 5,336
If the underside is open to the exterior, I would install plywood to cover the insulation to keep critters out of it. If it's an enclosed crawlspace, I'd only put plastic(6 mil) on the ground.
Vapor barrier up toward the heated space.
Ron
B. Franklin 1759
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
BIG PROBLEMS with cabin mud sills and floor scylla2 Building & Construction 1 10-18-2009 08:34 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
