Old 01-03-2007, 02:13 PM   #1
Insulating a bonus room
I am building a bonus room over a three car garage and live in a very cold part of the country. The floor is 2x8s. I am also planning to have a wood plank cathedral celing (2x10 rafters). How should I insulate the floor -- any vapor barrier to keep out fumes? How about the ceiling? Do I need to sheetrock?
dencrimi is offline   Reply With Quote
Old 01-03-2007, 03:25 PM   #2
concretemasonry's Avatar
Use fiberglass or cellulose between the gargae and bonus room. That barrier is not like the difference between inside and outside (much less temperature differential). Definitely use a vapor barrier on the warm side of the insulation. Your 5/8" sheet rock should be taped completely for fire protection purposes.
Catherdral ceilings are always a challenge in a colder climates. How cold do you thinks is cold -30F? - Your choices are a rigid extruded styrofoam applied to the exterior or filling the 2x10 cavity with the possible addition of rigid on the inside.
concretemasonry is offline   Reply With Quote
Old 01-03-2007, 06:40 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Absolutely....as was mentioned: 5/8" S/R with a minimum coat of 'fire-taping' on it.
- Build Well -
Old 01-06-2007, 01:53 PM   #4
NH Builder
You REALLY should be getting a building permit, fire protection is a HUGE deal with local authorities and frankly you want to protect your family. The building permit may also bring up a situation about your 2x8 floor joist, they may or may not be large enough.
As much as people hate getting permits, most inspectors actually can be quite useful and help you solve these problems.
Good luck!
NHBuilder is offline   Reply With Quote
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 11:35 AM
Finishing Upstairs Bonus Room luner99 Plumbing 5 02-26-2007 04:34 PM
Plumbing questions - finishing upstairs bonus room luner99 Building & Construction 1 02-07-2007 08:12 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 12:51 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
