Insulating Between Rafters - No Ridge Vent - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2008, 11:21 AM   #1
Rewards Points: 270
insulating between rafters - no ridge vent
i have a vaulted cieling with ridge vent. the last section of rafter (where the lookouts run out across the gable end to the rake) is not drilled or otherwise open to airflow to the peak.
spray foam guy says his product will seal it up air tight - sounds great but but I don't have the $ in the budget to get him out.
thinking I have to drill the lookouts a close as I can to the top side to allow air from the soffit up to the peak. before I do, I have a question - can I do a foam board "fix" in that last rafter section instead - cut some 1 or 2 " rigid styro board (which I have enough of now from the crawl insulation leftovers), snug fit up in the sections between the rafters / lookouts, and run a bead of spray foam like the expanding stuff along the edges / seams to make these areas / sections air-tight from below? will this work? if so, should I do this at the top side (against the sheathing) and then fill the rest with roxul underneath, or fill with roxul 1st and then the foam board flush with the bottom face of the rafter?
hope i'm making sense...
thanks
-randy
rtoni is offline   Reply With Quote
Old 01-12-2009, 10:16 AM   #2
Rewards Points: 270
Hi all - resurrecting this older post as I'm 99.9% compete with insulation - I used Roxul (mineral wool batts) everywhere - the area described in this post is the only remaining spot.
Does solid foam - board cut to fit, with a bead of spray foam around the edges - work in an unvented space? My thinking is this will provide a thermal barrier and a complete air seal, much like if someone spray foamed against the underside of the sheathing...?
Any feedback would be appreciated
Old 01-12-2009, 12:35 PM   #3
sounds good. some guys dont like to totally air tight the sheathing and if your one of those guys, put in some baffles first and then do what you want with the rigid foam
II Weeks is offline   Reply With Quote
Old 01-30-2009, 04:14 PM   #4
Rewards Points: 270
thanks II Weeks - appreciate the feedback....
Ridge Vent > Gable Vent jelly Roofing/Siding 10 06-09-2008 07:30 AM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 09:57 PM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 08:32 PM
