Insulating Below Rafters In 1-1/2 Story House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 11:56 PM   #1
Lightbulb
Insulating Below Rafters in 1-1/2 Story House
Our 1956 1-1/2 story house is in Minneapolis. The ceilings and knee walls are insulated but the side attics are outside temperature, causing the 2nd level to be cold all winter. The roof above the second level interior space is insulated with no space for ventilation between the side attics and ridge, which appears from outside to be vented. (Isn't that going to cause ice dams at the knee walls?)
There are only two roof vents on each side attic and vents along the eaves. After some reading, my plan is to install short lengths of furring strips on the underside of the rafters - spaced apart for ventilation. Then I would sheath the whole underside of the roof with pink foam boards and tape the joints.
I haven't read about that solution so I assume there is a problem with my design. Thanks for your advice.
jbeuckm is offline   Reply With Quote
Old 09-29-2010, 09:20 AM   #2
Chicago, IL
Michael Thomas's Avatar
Take a look here, the discussion is of insulating above a garage, but any under-roof conditioned space with knee walls has similar considerations:
www.dom.com/about/conservation/pdf/rooms_over_garages.pdf
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-29-2010, 11:59 AM   #3
Paul
The original method of insulating is correct; you normally keep any unused attic space cold to prevent ice dams. I was not sure from your description, but I assume that there is insulation between the floor of these side attics and the lower floor. If this is the case I would recommend you just increase the side wall insulation, just be careful that you don,t create a vapour barrier on the cold side of the wall.
Paul
www.finalsay.ca
finalsay.ca is offline   Reply With Quote
Tags
attic , furring strips , insulation , rafters , roof
2nd Floor Ventilation in OLD 2 story House Maggie Mae HVAC 2 07-19-2010 08:36 AM
Insulating a floor in the basement of a house bstreyle Building & Construction 4 01-26-2010 12:42 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
How do I efficiently run 2 a/c units for a 2 story house dlphnlvr_25 HVAC 1 04-24-2009 11:36 AM
Insulating house with stone walls mlupa Building & Construction 3 11-26-2008 09:19 PM
