Insulating Before Or After The Heat's On - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2008, 03:54 PM   #1
Rewards Points: 270
insulating before or after the heat's on
someone asked me this as I'm about to start the insulation in my project - in a vaulted ceiling - as I may have the heat on (getting chilly outside now) while I work.
in the ceiling I'm leaving a couple inches over the batts via the staple-on vents - so is there any worry about the heat inside possibly creating any condensation just before the batts go in - the airspace will be there anyway but just wondering if it's better to suck it up and work in the chill, get the batts in and covered with poly, or if the (small?) amount of condensation I might get with the heat on thru the day would make any difference at all.
not sure if this is an interesting or just plain dumb question....
randy
rtoni is offline   Reply With Quote
Old 10-07-2008, 07:58 PM   #2
If there is any condensation it will be so small as to not worry about it.
Marvin Gardens is offline   Reply With Quote
Old 10-07-2008, 08:07 PM   #3
Randy,
work in comfort.. As long as your batts are vented at the top and bottom of the bays properly it won't make any difference. RH in fiber glass batts will go up and down depending on ambient conditions.
Big Bob is offline   Reply With Quote
Old 10-07-2008, 08:36 PM   #4
Rewards Points: 270
thanks for the replies - feel a bit better now about keeping the heat on. bays are all (well) vented at eaves and ridge - so I assume air should flow ok. Just wasn't sure about the short interim period and murphy's law and all that - appreciate the feedback.
-randy
Old 10-07-2008, 09:38 PM   #5
Registered User
Termite's Avatar
Definately not going to be an issue for you.
Old 10-08-2008, 10:17 AM   #6
Rewards Points: 270
great - thanks again - should be up to my eyeballs this weekend - at least I'll be warm...
Question about insulating a garage forCcanadian winters trucker Building & Construction 3 02-08-2008 05:07 AM
Insulating House Paint basilbiko Painting 16 10-23-2007 05:15 PM
Insulating A/C ducting ? Scott_K HVAC 1 10-04-2007 06:21 PM
Heating zone heats some unused rooms ChessMan General DIY Discussions 2 11-10-2004 01:36 PM
