Insulating Basement Of Split Level Home. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 09:06 PM   #1
Insulating basement of split level home.
I'm in Ottawa Canada and I will be insulating my split level home's basement and wanted some advice on how to properly insulate the foundation walls.
My basement ceiling is 8 feet high. The foundation walls are 4 feet in the ground and the framing on top of the foundation is a regular 2x4 wall that ISN'T flush with the concrete wall....it juts to the outside anywhere from 1/2" to an inch. The basement is dry.
All of the research I've done points to only building a knee wall up to the top of the foundation and leaving the rest as is but I'm thinking of putting 2" XPS foam just high enough to cover the concrete foundation (4 feet) and building a 2x4 wall in front of that from concrete floor to bottom of joists but I'm not sure how I would tie a vapour barrier in for the top half of the wall. Is there a right way to do this? Or better yet, what is the preferred method of insulating a basement in a split level?
Here are some pics:
mmastran is offline   Reply With Quote
Old 08-11-2011, 09:33 PM   #2
AGWhitehouse's Avatar
You could run 2" foam from floor to ceiling and cover with sheetrock for the code required thermal and ignition covering required over foam. Will need to slice up the existing vapor barrier on the batt insulation to eliminate any moisture traps. The foam, providing proper thickness and composition, will provide the vapor barrier required of your geographical region.
Looks like any method you go with on the concrete will involve relocating the HVAC louver seen in the bottom right corner of your second photograph.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-11-2011, 09:39 PM   #3
Thanks for the reply. I was thinking of running the foam up the entire height of the wall but there would be anywhere from 1/2" to 1" of space between the the back of the XPS foam and the existing rockwool insulation on the top 4' wall since it doesn't sit flush with the concrete foundation.
Old 08-11-2011, 09:51 PM   #4
Run 1/2" or 1" foam on the lower part and then overlay with full height with thickness needed. Since not every stud is exactly a 1/2" or 1" off the foundation, you can shim the studs out with gypsum board furring strips to get the stud faces flush to accomodate the full height foam.
Old 08-13-2011, 11:05 AM   #5
Registered User
Rewards Points: 526
With only 4500+ HDD for your location, foam up past the concrete wall would be an over-kill for the money, in my opinion. It would also be putting the majority of the insulation in the stud bay rather than outside it to keep the wall sheathing warmer for less condensation problems. This would also slow the drying to the inside from an exterior water leak at the wood frame wall above grade. Your area requires R-13 cavity insulation, more than enough with two layers of batt (R-24) rather than foam board too (R-29).
Any gap between insulation or on the foam board/concrete would be prone to convective loops. Use the saved money on foam board and canned foam at the rim joists to air seal; pull the ineffective faced batts from there. Pull the paper facing from the batts, just slashing it would do next to nothing. Slashing would compromise an air barrier but not a vapor barrier or retarder.
Gary
Old 08-15-2011, 11:06 PM   #6
Gary, thanks for the reply.
Should I use a polyethylene VB on the top 4' or the whole of the basement wall, or at all?
Sorry, what does this mean?
What you suggest sounds different than what I had in mind on how to insulate. I've included an image from someone on the Mike Holmes forum with a similar basement setup as my own. The MAIN DIFFERENCE in mine is that the interior wall I'll build will sit IN FRONT of the XPS foam that insulates the lower 4' concrete foundation. The wall will run from the concrete slab to the bottom of the floor joists.
Any suggestions/improvements/changes you see?
thanks again!
Insulating basement of split level home.-basementinsulationsketch_version3_w.jpg
Old 08-16-2011, 12:17 AM   #7
Framer
Why not build a frost wall away from the concrete wall? Space it 1 inch from the concrete foundation and run it from your slab to the bottom side of your floor joists. Insulate all the way up with batt insulation and vapor barrier all with a good bead of acoustical sealant on the bottom to stop airflow.
Thats how we do it here...
Best of luck
joeyr is offline   Reply With Quote
Old 08-17-2011, 11:53 AM   #8
Sorry, but this makes no sense.
Old 08-17-2011, 12:06 PM   #9
Don't build that wall. The 2" of xps at the exterior coupled with a poly layer at the interior will create a double retarder system and will greatly increate the likelyhood of mold growth.
The foam from bottom to top would act as both an isulation barrier and vapor retarder. (2" of XPS is .75 perms which is a class II retarder).
Old 08-17-2011, 12:09 PM   #10
I would think that if the siding system fails he has more problems than where a vapor retarder is. vapor retarders are suppose to be on the warm-side-in-winter. That means at the interior considering the OP is in Canada. Can you explain why you are against the code standard?
Old 08-17-2011, 12:28 PM   #11
Guys, I appreciate all of the feedback...I really do
but I'm nowhere closer to figuring out how to properly insulate my basement given my PARTICULAR scenario.
Here's a recap: I'm in Ottawa, Canada and my basement is 8 feet (4 foot below grade, 4 foot above grade). I want to build a 2x4 wall from slab to floor joists...no knee walls. If I were to use 2" XPS on the top 4' above grade, and 1 - 1.5" XPS on the 4' below grade, do I need a VB? See pics above for what my basement looks like.
thanks,
Old 08-17-2011, 03:33 PM   #12
The foam itself at 2" is a class II vapor retarder. At 1" it is a class III. So if you ensure there is at least 2" of foam, then you will have a 0.75 perm, class II vapor retarder. I don't know your local code, so I'm not sure if you need a class I or class II.
Class I Vapor Retarder = 0.1 perms or less
Class II Vapor Retarder = 1.0 perms or less and greater than 0.1 perms
Class III Vapor Retarder = 10 perms or less and greater than 1.0 perms
DOW 1" thick XPS is 1.5 perms...
Old 08-17-2011, 09:38 PM   #13
Registered User
Rewards Points: 526
You may have some local modifications to your Code; http://www.about-building-in-canada.com/provincial.html
I haven't study this yet, only skimmed it, pp. 61--- onward addresses the vapor barriers: ftp://ftp.cmhc-schl.gc.ca/chic-ccdh/..._Web_sept5.pdf
To simply slash a vapor barrier will have effect only where the small slash is, letting through more air as a v.b. is area calculated. An air barrier is based on no holes or slashes; http://www.greenbuildingadvisor.com/...cience-podcast
Gary
Old 08-18-2011, 11:33 AM   #14
The first paragraph of the link supports my confusion. I think you're assuming a single cut of the vapor retarder. I'm talking about slicing and dicing, or two continuous, overlapping, serpentine cuts that allow for the removal of "diamonds" along it.
Old 08-20-2011, 11:45 AM   #15
Registered User
Rewards Points: 526
Now you described it correctly--- remove the facing. Any facing, slashed or not is a retarder.
Should the joints be taped?
Johns Manville does not recommend nor require that the joints be taped. Vapor retarders
are area weighted. The small gaps would not allow a significant amount of water vapor
through the wall, ceiling or floor.” From: http://www.insulating-products.com/p...lation_FAQ.pdf
To simply say “slash it” implies leaving it in place, at least to me, glad you added further instructions.
Gary
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 08:54 AM
Level basement sewer outflow question nmc Plumbing 6 05-22-2010 01:29 PM
Insulating to stop air infiltration in the basement. diy4life Building & Construction 51 06-11-2009 08:30 AM
Insulating - Rim/Header Joist - Basement AndrewF Building & Construction 7 02-26-2009 11:10 PM
