Insulating Basement Rec Room Walls. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 12:55 PM   #1
insulating basement rec room walls.
we live in wisconsin and i was wondering what is the best way to insulate,frame, and drywall for our climate.the block has already been coated with a sanded block filler and we have never really had any moisture issues.thanks
jdabroski is offline   Reply With Quote
Old 12-16-2010, 02:17 PM   #2
Rewards Points: 1,092
buildingscience.com, or ..../resources has lots of articles on this, as well as lots of discussion of it here. You may not have dampness, but I suspect you still have to deal w/ vapor. Air seal. Good luck, and read on! j
Old 12-16-2010, 08:09 PM   #3
Rewards Points: 162
Talk to your local building inspector regarding their requires (or lack of) for vapor barrier. I've finished two basements in my homes in WI and gotten two completely different opinions from the building inspectors in different municipalities.
Location #1 was vapor barrier directly in contact with the concrete foundation wall, then build your stud wall/insulate/drywall.
Locatoin #2 was no vapor barrier at all - let the wall breathe in case of moisture infiltration.
This is one subject where you are going to get a lot of different opinions.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 12-16-2010, 10:04 PM   #4
I watched a DIY program about this tonight. They glued 3" styrofoam to the concrete and then built a standard 2X4 framed wall in front to hang the board on.
They used no vapor barrier.
Old 12-16-2010, 11:27 PM   #5
Opinions, yes. That is why I prefer to read on buildingscience.com. Any vapor barrier, on either side of the wall, if against dirt, does not make sense to me at all. If you use the exterior vb to keep outside moisture from entering through the concrete blocks, then the moisture is trapped in the concrete. Great. Mold happens. The exterior of concrete needs impeccable sealing, IMO. Keep the water in the dirt, not the house. On another thread, MN4x4 said that a house he is familiar w/ HAD TO have an interior vb, even though the whole basement is below grade. That does not sound good.
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 09:54 AM
Insulating basement walls organick General DIY Discussions 7 10-30-2009 01:30 PM
Laundry room in the basement Trish99 Remodeling 3 10-19-2009 12:26 AM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
Insulating a unfiinshed basement govikes Building & Construction 7 03-26-2007 05:55 PM
