Insulating Basement Pipes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 10:18 PM   #1
gruntman's Avatar
Rewards Points: 79
Insulating basement pipes
All of my pipes from my gas boiler run along the ceiling of the basement and up to the heating elements. In the basement they are wrapped in this foam tube (not sure what its called). Im not sure if the wrap helps but its really ugly and Id like to improve the look of the side of the finished side of the basement. First, does this stuff make a difference, and (if the answer is yes) is there a better way yo do it?
Insulating basement pipes-img_5692.jpg   Insulating basement pipes-img_5693.jpg
gruntman is offline   Reply With Quote
Old 07-26-2009, 07:02 PM   #2
TooledUp
Yes, it definately makes a difference. However, it depends on your humidity control in your basement. If you can keep it down with a dehumidifier, you may not need the insulation.
TooledUp is offline   Reply With Quote
Old 07-26-2009, 10:27 PM   #3
gruntman's Avatar
Rewards Points: 79
Why is low humidity important? I dont have water but it does get humid.
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 09:54 AM
Insulating to stop air infiltration in the basement. diy4life Building & Construction 51 06-11-2009 09:30 AM
Insulating - Rim/Header Joist - Basement AndrewF Building & Construction 7 02-27-2009 12:10 AM
worth insulating pipes? wombosi HVAC 4 02-15-2009 07:32 PM
Insulating Steam Pipes Densec General DIY Discussions 5 01-04-2009 10:14 PM
