Old 11-24-2009, 12:15 AM   #1
Question
Insulating a basement floor
I looked for this topic in other threads but couldn't find anything...
I'm hoping to get a bit of guidance/advice before we get into insulating a very cold (& ugly) basement floor.
I want to lose as little headroom as possible, so am hoping to go with either 1/2" or 1" foam on the floor with strapping (lathe?) @ 16". What info I have read suggests using treated wood, but am at a loss at what to use as the only treated I've seen around is 2X (1 1/2"). Maybe this is a dumb question but here goes: Is there such a thing as treated plywood? If I could have a sheet ripped down to 2" wide strips couldn't that work as the nailing strip that would be attached to the floor between each foam board? Or is the only solution ripping 2 X's down to the right depth?
PS: Yes, a vapour/moisture barrier will be put down first!
I look forward to any input here, thanks.
churchlady is offline   Reply With Quote
Tags
basement insulation
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Basement Floor Gardengirl Building & Construction 4 06-02-2009 06:38 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
waterproof basement floor?? patnshan Remodeling 3 09-07-2006 02:58 PM
