Insulating Basement Cold Room. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 04:02 PM   #1
Insulating basement cold room.
I am building a small 6x8 cold room in the northeast corner of my basement. The two outside walls are concrete, the two inside walls are 2x6, insulated with R22 Roxul. The space above, on the main floor of the house, is the kitchen. I am putting R22 Roxul in the ceiling joists of the basement. My question is - should I put the 6 mil vapour barrier in the joists first, then insulate, or should I insulate and then put the vapour barrier. In other words, which side of the insulation does the vapour barrier go?
blizmore is offline   Reply With Quote
FInished basement area too cold richardnml HVAC 0 06-19-2010 01:39 PM
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
How to insulate a cold room valley boy Building & Construction 1 11-10-2009 09:50 AM
Insulating basement ceiling? pastfast125 General DIY Discussions 2 03-30-2007 06:14 AM
