Old 11-01-2009, 02:27 PM   #16
No, the 1" space is between the wood and the foam board. The foam glues directly to the concrete wall. It's in the article I left, towards the bottom. I would slip some 6"sticky window tape behind the studs - vertically, center stuck to the stud and ends stuck to the foam board cut to fit in stud bays. So you seal gaps between foam boards on the other side of board.
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 11-01-2009, 03:06 PM   #17
Thanks! Good idea!
joan518 is offline   Reply With Quote
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
If you have the need to store large amounts of ice, building an ice house is a project for you. Popular many years ago, now most freezers now come equipped with ice makers to produce a sufficient amount of ice for a family, but are not designed to handle... Read More »
On behalf of Expert Village my name is Bob Lanning. I'm here to tell you about make a train diorama in HO scale. This area here shows a, kind of a typical Verde Valley ranch. I think most diorama's look good if they have a lot of figures. We have the... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you for a minute about these arched windows like this. Okay we've put... Read More »
Insulating a painted basement wall BasementVirgin Building & Construction 8 09-28-2009 01:27 PM
Insulating basement pipes gruntman Building & Construction 2 07-26-2009 11:27 PM
insulating duct work in basement Master Brian HVAC 10 05-19-2009 12:28 PM
Insulating - Rim/Header Joist - Basement AndrewF Building & Construction 7 02-27-2009 01:10 AM
Spray foam insulating joists in basement? peethree Building & Construction 6 08-24-2007 09:21 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
