Prev Previous Post   Next Post Next
Old 10-28-2009, 12:18 PM   #1
Default Insulating a basement
I have read many different replies regarding insulating the basement walls and not. Also I have been told not to install a vapor barrier. One source I talked with said, that I should just build the walls 1" away from the poured concrete and than install the drywall. I have already studded out my basement, leaving a 1" gap from the pour walls. Do I even need insulation in the cavity ? Do I apply any vapor barrier ? Do I now cut pink or blue foam and stick it within the studs ? Help, I also live in the Chicago area.
Snyder-man is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
So this is the second step with blowing insulation into existing walls. You already have these holes cut in the wall and the insulation is all blown in and you need to patch this hole. There are a few options and the one that I am choosing is to fill it... Read More »
This area. But if you feel like you want to do for insulation-wise, you can do this too. For insulation wise, too. 'Cause sometimes your walls, you know, certain walls like that back wall there...if you can't put nothing inside the wall you can put... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
So the next step to insulating an existing wall is to patch the hole that has now been filled with expandable insulation with drywall compound and you will want to apply this with a putty knife. You want something fairly wide. You want it to be at 1... Read More »
Insulating basement pipes gruntman Building & Construction 2 07-26-2009 11:27 PM
Insulating to stop air infiltration in the basement. diy4life Building & Construction 54 06-11-2009 10:45 AM
insulating duct work in basement Master Brian HVAC 10 05-19-2009 12:28 PM
Insulating - Rim/Header Joist - Basement AndrewF Building & Construction 7 02-27-2009 01:10 AM
Spray foam insulating joists in basement? peethree Building & Construction 6 08-24-2007 09:21 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
