When framing a basement and insulating, should the insulation go all the way down, or should I leave a few feet of uninsulated wall? Does some heat need to go in the foundation to keep it from cracking in winter?
Also when putting the vapor barrier would I just make it go all the way down, and also cover the floor where the bottom studs would lead to ensure I don't have wood directly on cement?
Whatever rule applies to full basements can it also apply to crawlspaces? When I search for anything related to crawlspaces I get really nasty looking ones (and I thought mine was bad!). This is a fairly clean crawlspace especially now that I've cleaned it all up of spider webs and stuff. Not much moisture (just some humidity and lime deposits)
Some pics here to get an idea:
http://gal.redsquirrel.me/?level=picture&id=502
I'd like to frame all the perimeter and insulate it at some point.
