Insulating Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 08:09 AM   #1
Insulating basement
We are wanting to insulate the basement, wandering which way to go , batts or spray insulation?
verla is offline   Reply With Quote
Old 02-23-2012, 08:16 AM   #2
Rewards Points: 150
Well that all depends. Do you want to DIY this project. Spray foam is not typically a DIY job, although it can be done with rented equipement. Spray foam will also be alot more expensive. I would figure out the cost of doing both and you might get your answer pretty quick. I have a couple buddies that own a spray foam insulation outfit and they still haven't been able to convince me that it WAYYYY better than traditional insulation methods.
psilva8 is offline   Reply With Quote
Old 02-23-2012, 08:25 AM   #3
Rewards Points: 674
Price it out, that may make your decision for you.
There are a million "Basement Insulation" threads in the 'Insulation' section with a million and one helpful links. Read up on them and that should be helpful to you also.
B
Beepster is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Insulating my basement DanS281 Carpentry 1 08-28-2011 03:05 PM
Insulating unfinished basement, First time home owner please help! ashory Building & Construction 7 08-25-2011 11:44 PM
Insulating basement of split level home. mmastran Building & Construction 23 08-24-2011 06:19 AM
Insulating partial in-ground basement? HiccaBurp Building & Construction 6 10-25-2010 10:03 PM
