Insulating Balloon-Framed Attics - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 09:26 AM   #1
Hi All
I have a century home (1865) triple-brick, balloon framed construction.
There is a mixture of fiberglass batt and blown-in cellulose (8" total) attic insulation. I just installed rafter baffles in preparation for more blown-in (up to R50). While in the attic I noticed the balloon-framed interior walls- Should I cap the walls with wood, cover well with batts or insulate from the inside with Roxul when I replace the deteriorated lathe & plaster walls this spring?
There is only one spot on the roof without snow- right above one of the interior walls.
thanks in advance for your advice
dgh1 is offline   Reply With Quote
Old 01-01-2012, 09:28 AM   #2
Rewards Points: 14,026
They really need to be blocked off at the top and at the bottom to cut off the air flow.
dgh1 (01-01-2012)
Old 01-01-2012, 02:58 PM   #3
Rewards Points: 2,212
Cap it with whatever is easiest and best. I would consider poly and acoustical sealent.
mae-ling is offline   Reply With Quote
Balloon framed exterior wall questions WillK Insulation 6 12-20-2011 10:28 PM
Insulating rim joist in odd balloon frame like construction bubbler Insulation 9 09-29-2011 08:45 AM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
