Insulating An Attic With T&g Floor In Place - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 01:52 PM   #1
insulating an attic with t&g floor in place
I have a 1400sf walk up attic with ZERO insulation between 2x10 joists.
The tounge and groove flooring has been in place since 1925, the fastners are tougher than Mike Ditka.
How do I get insulation under the flooring without having to rip it all up?
Anyone been through this?
on the level is offline   Reply With Quote
Old 11-14-2010, 06:28 PM   #2
since the floor is (should be) laid perpendicular to the joists, you could just pull up a few boards in the attic, and then blow cellulose into the cavities. pulling up some boards in the middle and around the edges should give you sufficient access to make sure that you don't end up with any voids in your insulation.
1910NE is offline   Reply With Quote
Old 11-15-2010, 05:46 PM   #3
yes, what the other guy said.
if the boards are nailed through the tongues, here's what i would do:
take a skilsaw and set the depth of cut to the board thickness. then rip a line straight down the middle of the board. the "groove" half will lift right out, and the tongue half will pry out easily with a bar/hammer. then they both can be nicely reinstalled after.
if the nails are through the face, i would take a cat's paw to the nails on the groove side, and do the same method as above.
good luck.
wombosi is offline   Reply With Quote
Old 11-16-2010, 09:18 PM   #4
a less messy, but more costly option may be styrofoam on top of the planks and then put 3/4" plywood overtop of the styrofoam so you can still use the space. "Blow in" insulation sounds good too.
the carpenter is offline   Reply With Quote
Tags
attic insulation
Insulating garage / adding attic Red Squirrel Building & Construction 4 04-19-2010 07:33 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Insulating walkin attic Kurt1968 Building & Construction 17 12-10-2009 05:19 PM
Insulating attic floor AND rafters? John FX General DIY Discussions 11 10-10-2008 10:50 PM
Insulating walls between attic & heated area Hobiedog Remodeling 4 11-08-2007 03:56 PM
