Insulating Attic With Rigid Foam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 10:39 AM   #1
Rewards Points: 24
Insulating attic with rigid foam
I am insulating the floor of a vented attic in a side-split. This is the attic on the lower side of the house. If you know how a side split is built, then you also know that the attic on the lower part of the house has a wall which is common to the higher side of the house. It is in essence an outside wall. Usually this is next to a bedroom. That room can be quite cold. Insulating the attic floor does nothing for that room since this wall is above the insulation. I am planning to put rigid foam board on this wall. Do I need to cover this foam board to meet firecode.
giannit is offline   Reply With Quote
Insulating Basement w/ Rigid Foam and Batt Reilley Building & Construction 4 08-03-2013 10:07 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Leveling Basement Floor Rigid Foam mdenis Building & Construction 6 09-07-2009 04:55 PM
Insulating my attic using 4X8 rigid foam board Vermont1 Building & Construction 8 04-30-2009 11:15 AM
