Insulating Attached Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2007, 06:57 PM   #1
Insulating attached garage
I've just bought a house in New England with an attached garage. The walls are insulated, but the ceiling is open (no insulation or sheet rock). Do I need to sheet rock the ceiling to insulate, or can I leave the ceiling open and just insulate between the ceiling joists? What is the best way to go?
Hal2001 is offline   Reply With Quote
Old 10-16-2007, 09:13 PM   #2
kemerick's Avatar
Rewards Points: 87
Insulation with drywall is better than just insulation. The best insulation is air... so trapping the air with the drywall will help the insulation perform better.
My constant project is my home, my play time is usually spent on my CNC router.
kemerick is offline   Reply With Quote
Old 10-16-2007, 10:48 PM   #3
like stated above, you are better off with drywall as well but you can get insulation and just staple it to the joists. If your gonna go with the drywall, do it right and tape the joints as well.
JFD140 is offline   Reply With Quote
Old 10-17-2007, 07:33 AM   #4
Doesn't code usually require that faced insulation is covered with drywall in a garage? You might want to check that out.
NateHanson is offline   Reply With Quote
Old 10-17-2007, 11:49 AM   #5
Rewards Points: 1,910
If you don't cover it it will also eventually become a pain as it starts settling and drooping. I know this because I am now experiencing it first hand in my 16' high metal building. It looked great when I bought it the place but is now starting to come down. It was suppported by staples as well as a layer of 6 mil ploy stapled to the joists.
Drywall is probably the least expensive cover that will meet fire requirements. A garage is a great place to work on your taping skills!
Old 10-17-2007, 04:46 PM   #6
o yea its also nice when the particles start hitting the air if it does fall when your in there. Its good to breathe in.
Old 10-17-2007, 05:32 PM   #7
General Contractor
joasis's Avatar
The best option is to drywall it, or at least use OSB, and then have cellulose blown in....also a DIY project.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 10-24-2007, 11:53 AM   #8
Since this is a garage, what about using plywood paneling instead of drywall? It would be easier to install. That's what I did on outer garage walls. I would think the same could be done on the ceiling.
dderolph is offline   Reply With Quote
Old 10-24-2007, 06:28 PM   #9
Rewards Points: 5,336
Code generally requires firecode(5/8") sheetrock in the garage. If you're not heating the garage, why would you put insulation in?
Ron
Should I insulate an attached garage? pbkid Building & Construction 11 07-09-2011 03:31 PM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Excavating under attached garage. TNRocks Building & Construction 2 05-02-2007 04:54 PM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 11:30 AM
