Insulating Around Chimney - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 10:04 AM   #1
Rewards Points: 93
insulating around chimney
Whats the correct method for insulating around a chimney? I know that I must use unfaced batts, but can they contact the chimney? Should I use something to seal the gap between the chimney and the roof decking? or is the insulation suffiecient? If I use a sealant is there a specific kind? Thanks
bfan781 is offline   Reply With Quote
Old 06-16-2010, 01:27 PM   #2
Totally screwed together
What kind of chimeny? Are you talking about old brick or new metal?
xxPaulCPxx is offline   Reply With Quote
Old 06-17-2010, 12:26 PM   #3
Rewards Points: 93
Great! It is an older brick chimney with a liner. Any info would be great as to how I should approach this.
Old 06-17-2010, 12:55 PM   #4
Most people use a product called "Mineral wool". It insulates AND is fireproof. Don't forget to use metal flashing to seal up any gaps around the chimeney.
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Chimney Confusion (Long) wehcyar Building & Construction 7 09-03-2008 10:09 AM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
