Insulating Above Unused Attic Fan. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 02:30 PM   #1
Just call me Andrew
Rewards Points: 1,020
Insulating above unused attic fan.
My parents have an old (no-longer-used) attic fan. The fan is in the ceiling of the second floor, and blows upwards into the attic to exhaust the heat. They now have air conditioning and don't use it anymore.
I am trying to construct some sort of insulation tent over the fan, in the attic. My plan was to use 2" thick rigid foam insulation to build a sort of "upside-down box" to put over the fan, and maybe line the inside of the box with R-13 fiberglass batts.
Does this sound like a feasible idea?
Can I just use caulk to "glue" the pieces of rigid foam together, or should I use some other sort of adhesive?
How do I adhere the batts to the inside of the foam "box"?
Thanks.
secutanudu is offline   Reply With Quote
Old 11-28-2009, 03:28 PM   #2
Kekeever
Kyle Keever's Avatar
Wouldn't it be easier to take the fan out, put up drywall and insulate with fiberglass bats in the attic?
Kyle Keever is offline   Reply With Quote
Old 11-29-2009, 07:15 AM   #3
Just call me Andrew
Possibly, but I have a feeling they will want to leave the fan in.
Insulating a finished attic properly? kokanee123 Roofing/Siding 13 09-18-2009 09:48 PM
Insulating Semi-Finished Attic... Need info scrupul0us General DIY Discussions 8 12-03-2008 01:25 PM
Insulating attic floor AND rafters? John FX General DIY Discussions 11 10-10-2008 10:50 PM
Insulating an attic for HVAC system BigJimmy Building & Construction 7 10-07-2006 09:10 PM
Insulating Attic? Vikeologist Roofing/Siding 1 08-03-2006 11:16 AM
