Old 01-25-2011, 11:46 PM   #1
Insulating
Originally Posted by philmeup View Post
I have a tri- level home,with a heated wall up against a un- insulated garage I now have a leak in my living space,it is 5F here today,and tons of snow on the garage roof,I am thinking that it is a ice build up,under the shingles ?
But could this be condensation between the heated wall,and the cold air from outside,causing moisture on my floor sill,which appears to be wet.
Thanks,Phil
Is the wall in the garage covered? You could try putting xps foam in the cavity and sealing the edges.
benjamincall is offline   Reply With Quote
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 01:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 04:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
