Insulating - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 10:15 AM   #1
Insulating
I have a tri- level home,with a heated wall up against a un- insulated garage I now have a leak in my living space,it is 5F here today,and tons of snow on the garage roof,I am thinking that it is a ice build up,under the shingles ?
But could this be condensation between the heated wall,and the cold air from outside,causing moisture on my floor sill,which appears to be wet.
Thanks,Phil
philmeup is offline   Reply With Quote
Insulating furnace/utility area cbrc5eric Building & Construction 3 04-30-2010 12:03 PM
Options for insulating a concrete block house Ptron Building & Construction 7 04-05-2010 03:55 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
